Add-on waterpump parts ?
50 A
04-01-2003 13:09:22
I have a 50 A that has an add-on waterpump; not a factory waterpump. The only identification on the pump is the number 51. Is this a Johnson product? I need to replace the seals and bearings. Local JD part's man has no clue on what brand or kit to use for repairing this waterpump.
Will P
04-01-2003 14:17:45
 Re: Add-on waterpump parts ? in reply to 50 A, 04-01-2003 13:09:22
I can't help you with your pump identification, but does it look like the link I posted? Hopefully it will help someone else.
Will P
50 A- That's the waterpump- Thanks! Will P
04-01-2003 15:55:22
 Re: Re: Add-on waterpump parts ? in reply to Will P, 04-01-2003 14:17:45
So can anyone tell me if parts are available.
Thanks again!
Lee
04-01-2003 21:50:14
 Re: Re: Re: Add-on waterpump parts ? in reply to 50 A- That's the waterpump- Thanks! Will P, 04-01-2003 15:55:22
Interesting setup, never seen one before. Your Deere parts guy might not be the best guy for the job at hand if he's worried about part numbers. Most automotive water pumps use the exact same bearing assembly. And most automotive seal setups are identical to the one we have on our shallow well jet pump for the house. Conclusion - get somebody who has rebuilt several water pumps, he already has the parts you need on the shelf.
I used to keep the seals for house pumps in seperate boxes with manufacturer written on the box. Then I looked inside and found them all to be the same seal, so now I keep them on a wire loop.
50 A-thanks Lee. I thought parts for a chevy waterpump will fit.
04-02-2003 06:38:17
 Re: Re: Re: Re: Add-on waterpump parts ? in reply to Lee, 04-01-2003 21:50:14
My dad recalled that he might have used parts from an automotive pump to repair the pump previously.
