JD six and maybe four cylinder history con't
G Taylor
04-01-2003 09:49:28
So if I understand this the 4010's engine has grown into the mighty and large 6081. Is anything other than the bore centres,head bolt pattern and maybe the deck height similar? Bellhousing pattern the same? The mighty dinosaurs 6531 and 6619 must have died out for one reason or another? Weak bottom ends? Was the 50,55,60 or the new 8000 series the end of them? The 6076??? Doesn't it also displace about 466 like the 4050 tractor's etc engines? Any relation? The 6068 used in the 6000 series? Related to anything or a clean sheet of paper? The mighty 6125 must swing a set of pistons and stroke bigger than a 620's, even a 60?
