John Deere 8760 and other large 4wd jd question
Rick
03-30-2003 14:00:03
was wondering about the transmission on these large 4wd john deere tractors. Did john deere build the 24 speed tranmission? I have read that it was a partial power shift and was wondering how did that work? Also who built the engine that went into these tractors?
john
03-30-2003 19:36:16
 Re: John Deere 8760 and other large 4wd jd question in reply to Rick, 03-30-2003 14:00:03
I have a friend who has a 8760 with the 24 speed trans. its basicly a quad range with gears 5 and 6 added to it to make 24 speeds. im not sure if deere makes the transmission but they probably do. the engine in this tractor is the deere 619cid this is a very nice tractor to operate. also my neibor has a deere 8960 which is the largest in this series and it has a 12 speed powershift trans.the only problem i see wrong with this trans is that every time you clutch the tractor it automaticly goes back to 1st gear,which can be tricky on the road. this tractor has a cummins 855 in it turning 425+ hp,which the cummins is standard equipment on the 8960 and 8970 tractors. hope this helps
