You have a real gem among the JD utilities. I have a '73 JD 1020 Diesel that is used for loader work, the JD 48 QT loader is an engineered match, and field work, 9ft Haybine and JD 336 baler w/kicker. I've put my "little" 1020 to work plowing, 2x16" in heavy soils, and disking with a 10ft rig. These tasks do push the JD 1020 Diesel engine to its maximum sustainable power level and I would not recommend making these field chores "regular" tasks on your work schedule. The point is your 1020 diesel is one "tough and ready" working utility tractor that has more reserve than one might think! To take advantage of the 1020's potential, I weight each tire with 612 lbs of calcium and I have the Factory ROS and Canopy, which adds another 438 lbs. HJ's point regarding over working the JD 1020, "like a big tractor", is a good one to bear in mind, but don't be reluctant to "push" this "bulldog" to its upper limits on occasion! Get to know your JD 1020 Diesel by slowly increasing its work assignments and monitoring its responce. You'll find your "little" diesel has a lot to teach you! Walt, have fun... but, above all other considerations... safety first!
