60 gas lines
ron
03-29-2003 16:37:47
New to JD. I noticed that their is 3 line exiting the sediment bowl; two smal 1/8" line look like they go into theblock. What is the deal with this arrangment?
Thanks
SamH
03-29-2003 20:37:33
 Re: 60 gas lines in reply to ron, 03-29-2003 16:37:47
Along with the usual gas lines, your tractor has a 3rd line coming from the crankcase. When the tractor is running, the engine oil pressure opens a valve atop the sediment bowl and lets fuel through. When the tractor is turned off, the valve closes. This system was designed to keep fuel from leaking through the lines and into the crankcase. With age, the diaphram that operates this system may no longer do its job. If you notice fuel in the crankcase, this is the first place to check. The diaphram is still available from Deere and doesn't cost very much.
Randy
03-29-2003 16:56:28
Two of the lines bring oil presure to the seiment bowl to turn the flow of gas on, it has a baffle in the top of it. The other is the gas line.
