38 A timing
38 A
03-29-2003 12:45:29
i am putting a 38 A unstyled back together and am at the point i am trying to get it to fire i have spark one cylinder seems to be hitting at the right time but i also keep getting some backfires trough the carb am i 180 degrees out on the mag (wico type c)
Clooney
03-30-2003 05:07:45
 Re: 38 A timing in reply to 38 A, 03-29-2003 12:45:29
38 A, with the Wico C if the spark is correct for one side it should be correct for the other side. If you are 180� out of time both sides will be off. ~To check the spark timing... remove both spark plugs, then with the plugs still in the wires just lay them on the block & turn the flywheel in the running direction & watch for a spark from the L/H plug when the L/H impulse on the flywheel lines up with the case mark [at 3 o'clock behind flywheel], then the R/H plug should spark 1/2 turn flywheel turn later.
~You could have a cracked mag cap, or carbon tracking in the cap, or some other reasons the wires are arcing together. ~A sticking valve, or incorrectly set or malfunctioning carb can also cause the backfiring.
~It might not hurt to do a cranking compression test to see what you have.....
38 A
03-30-2003 10:18:13
 Re: Re: 38 A timing in reply to Clooney , 03-30-2003 05:07:45
my problem must be with the carb then because i am getting the Lh spark at the impulse mark and i just put a new cap on the mag the head was off and redone but i dont know much about the carb i have the idle opened 1 1/2 and the load 1 turn it pops & snorts i think if i get some one to pull me it might fire
Clooney
03-30-2003 10:37:51
 Re: Re: Re: 38 A timing in reply to 38 A, 03-30-2003 10:18:13
38A, try running with the choke partially back on to see if that helps, if so you probably have a carb problem. See your E-Mail for more info..
Village Blacksmith
03-29-2003 23:16:02
Go up the page and read about "Timing the 36 B". This should cover it.
