4010 gasoline engine noise
A.B.
03-28-2003 14:30:13
Suddenly developed engine noise on my 4010 gasoline when I started it up. Fairly loud - metal to metal thumping / banging. I am unable to tell if coming from top/bottom/left/right of engine - it just sounds "deep internal". Engine starts, runs, and accelerates - but not smoothly and noise increases with RPM's. Suspected it was bearings - pulled oil pan - checked connecting rods - no excessive bearing play evident - no excessive metal pieces in oil. Plugs look like they are all firing. What should I check next?
ErnieD
03-29-2003 16:37:44
 Re: 4010 gasoline engine noise in reply to A.B., 03-28-2003 14:30:13
Broken valve?
Scott Conner
03-29-2003 12:51:32
I changed the hydraulic pump coupling to the newer style like on a 4020 on mine. The original couplings on the 10 series make noise like a rod knocking but since you say the engine runs sluggish, this probably isn't what's making the noise.
James Bridges
03-29-2003 00:39:30
I had the hard face on the bottem of a lifter come loose and it sounded just like a rod. Check the lifters before you get to far into the eng.
Jim - AK
Alan K
03-28-2003 18:01:33
Maybe it could be a wrist pin. You could possibly try shorting out the spark plugs one at a time to see if the noise lessens or changes. If it came all of a sudden I wouldn't think it would be wrist pin unless something drastic happened.
fritz
03-28-2003 16:05:37
check flywheel bolts.good luck Fritz.
Bob
03-28-2003 15:01:50
Check coupler at front of crankshaft to hydraulic pump, and while your there, check the torsional damper.
JD
03-28-2003 15:24:18
 Re: Re: 4010 gasoline engine noise in reply to Bob, 03-28-2003 15:01:50
A gas does not have a damper.
