John Deere 71 planter units
Rev JJ
03-27-2003 19:08:27
Can the model 71 flex planter units be used for any thing other than peanuts? They are don't have plates, per se, but an edge drop affair. looking at one maybe for corn, beans, milo.
T. Taylor
03-28-2003 07:50:08
 Re: John Deere 71 planter units in reply to Rev JJ, 03-27-2003 19:08:27
The edge drop affair that you referred to, if mounted vertically, is a plateless unit. This model uses two separate units to select seed, a finger pick-up unit for corn and a seed cup mechanism for soybeans and milo. The seed cup mechanism has different size cups available for various seed types. If the finger pick-up units are not available with this planter, they might be hard to find used and are certainly expensive new from Deere.
zane
03-28-2003 05:11:34
The 71 planter will handle most any row crop except for those with very small seeds (turnips, cabbabe, grass, etc.) They do carry plates, which are specific for the crop, seeding rate, etc. We say "plates"; they are more like rings. Your seed dealer of JD carries them.
Howard H.
03-27-2003 19:53:29
Hi,
Sure - they'll plant a lot of different crops. We used to plant a lot of milo and corn with them.
Just have to get the appropriate plates for whatever you're putting in the ground.
Our local seed dealer used to keep all sorts of plates for them. Some of them were really odd looking. Even for squash and watermelon, if I remember correctly...
Howard H.
stewart
03-28-2003 04:00:29
 Re: Re: John Deere 71 planter units in reply to Howard H., 03-27-2003 19:53:29
I plant all my corn with a 4 row made up of 71 flex units. Great little planter
Hoosier
03-27-2003 19:16:41
We used the 71 units to plant soybeans. Could also plant corn by changing the plates.
