Installing studs in cylinder block
JD-G
03-27-2003 07:53:06
I'm reinstalling the studs in the cylinder block but noticed some of these studs screw into the water jacket. I've heard from some that you should use something like antiseize on the threads and others have suggested using teflon tape. What is the best way to seal this off or what's proper to use on all of the threads for these studs?
JD-G
03-28-2003 07:21:34
 Re: installing studs in cylinder block in reply to JD-G, 03-27-2003 07:53:06
Thanks for the followup guys. Hopefully, it won't be long now before I'll have the old girl running.
Mike Aylward
03-27-2003 11:41:04
JD-G, if you will notice on the studs one end is flat and one is round. The flat end goes into the block. The threads are not cut quite as deep as the round end is and this provides a slight interference fit. I usually use a light coating of #3 Permatex on these studs before installation. It is also a lot easier to install them when the block is already in the tractor. I usually double nut the round end and install. Not a big deal. Mike
blake
03-27-2003 19:48:08
 Re: Re: installing studs in cylinder block in reply to Mike Aylward, 03-27-2003 11:41:04
I use make gasket compound that i buy from napa the first time I put studs into the water jacket they leaked after that I asked a machinist what he uses when he rebuild s engines and thats what he recomended since then I put it on all studs that go into the water jacket and haven't had one leak since
CMB
03-27-2003 08:28:34
It would be good if you could have the studs sealed & I suppose there any number of sealers that will do this, but it really isn't necessary, as that's what the lead washers under the head nuts are there for. I also believe the washers provide some lubrication as the head is tightned.
Ralph
03-27-2003 08:06:16
I'm not a mechanic!! I hire one when it comes to overhauls, but I think if you look at those studs, the threads on the block end are slightly "oversize". They will seal if turned in tight. I would probably use some anti-seize, but have gotten to dislike teflon tape. The last batch I got was string-like at best and granular at worst.
