Jd 70's propane tank capacity and demensions
mr propane
03-26-2003 21:05:13
just wondering the demensions of the LP tank on a 50, 60, 70, or 80 or any other jd propane tractor.
or any other tractor for that matter. need it to fit under a pick-up.
Tom in Mo.
03-27-2003 17:50:28
 Re: jd 70's propane tank capacity and demensions in reply to mr propane, 03-26-2003 21:05:13
To find a propane tank with a small enough diameter to fit UNDER a pickup won't hold enough gas to do you any good. That's why they are always in the bed taking up room. You might also consider you will use more gallons per mile than gasoline and they are more inconvenient to fill. The 70 tank probably holds the same as a 630 which is 33 gallons at 85% fill.
Note: I believe the orchard models had a larger tank but it would be worth more than your pickup.
bill
03-27-2003 16:05:03
this is a guess, Id say 18 inches wide and 4 foot long;;;have seen a few in salage yards.
