JD PLOW TROUBLES
DCPULLER
03-26-2003 13:36:20
Have a 2 bottom trip plow made in the 50's? Has a sealed gearbox on clutch wheel. Need to get the rim of that side to blast and paint how do I do it ? Took the three bolts out and th pin and the adjusting ring but rim will only come of about an inch . What do I need to do? Thank you
Bob Collins
03-27-2003 08:24:16
 Re: JD PLOW TROUBLES in reply to DCPULLER, 03-26-2003 13:36:20
DCP, With the hub cap off (by removing the 3 nuts) don't remove the pin in the axle. use a large puller or a jack and chain CAREFULLY hooked to the hub of the wheel, try not to grab the spokes, push against the end of the axle. I like to thump the hub of the wheel from behind with a block of hard wood and mall while applying pressure. the wheel should pop off the tapered drive splines. Good luck.
KrisA
03-26-2003 14:34:31
DCPuller, just had my #52 plow apart and all that I did was twist the end cap off (it should have a set bolt and a grease buddy in it. Then I took the pin out and the adjusting cap and the shims and it just slide right off. I couldn't tell by your description if that is what you did. That is all I did. Hope that helps
KrisA
