1936 D connecting rod torque values
dale
01-07-2004 01:44:53
Fixing to take up the slack in the rods by removing a few shims, but can't find a torque specification for when I get to tightening everything back up. Anybody got an idea? (couldnt find anything in the owners manual, or I&T book...)
JC
01-07-2004 18:42:37
 Re: 1936 D connecting rod torque values in reply to dale, 01-07-2004 01:44:53
Suggest you plastigauge the rods while you are torquing them. The I&T manual provides recommended clearance.
dale
01-07-2004 12:19:48
all right, as long as they're 'tween 80-90 lbs., I should be good to go... thank you, guys.
Duane Larson
01-07-2004 07:48:45
Dale,
JD Field Service Bulletin 163 (8/15/49), lists D rod bolt torque as 90 ft lb, with the added comment to "torque to 90 ft-lb, then tighten further as necessary to insert cotter pin".
FWIW, this FSB was JD's first offering of torque values for tractors, "in response to repeated requests from our service organizations". WW-II used torque wrenches a lot for servicing, and when the men returned to the farm equipment shops they wanted to know torque values. Prior to that bolts and nuts were just "tightened".
Bob-Wyo
01-07-2004 05:47:57
Dale my book shows 80 foot pounds.
Bob
