Best mower for a B
Bud Man
03-25-2003 11:27:20
I have a 1950 b. I want to use it to mow and I am wonder what would be the best set up. I'm wanting to finish mow not bush hog.
John T
03-25-2003 12:34:41
 Re: Best mower for a B in reply to Bud Man, 03-25-2003 11:27:20
Hi Bud Man, If you dont want to fool with any 3 pt or lift arm raised type of mowers, I would use a 6 ft or so pull type finish mower, NOT a brush hog of course. I say 6 ft. or so, because I would prefer it be wide enough to cut a swath nearly as wide as the wheel tracks?? (whats your rear width with the wheels set all way in??) While a 6 ft brush hog in heavy brush would be too much of a load for a B, if youre just pulling a lighter finer finish type mower over lawn grass, it should handle it.
Good Luck n God Bless the USA Ol John T Nordhoff in Indiana
Handsome Jim
03-26-2003 17:07:41
 Re: Re: Best mower for a B in reply to John T, 03-25-2003 12:34:41
You got me thinking John T. Is there such a thing as a pull type finish mower? BTW, Any news from your leatherneck? My nephew Travis was discharged from the Marines February 02 and some of his buddies have been called back this last few weeks. I don't think he'll be called back because he's married with twin two year olds. If the Marines take him they'll be responsible for the whole bunch. Good Luck.HJ
Chuck W
03-25-2003 11:31:00
I've ran a 6' landpride off jd lift arms etc...on a B. Worked fine..have to stabilize side movement of the control arms....
JD-Tractor
03-25-2003 13:14:35
 Re: Re: Best mower for a B in reply to Chuck W, 03-25-2003 11:31:00
Do yourself a favor and make sure you use an overide clutch on your pto clutch it might just save your transmission !
