Rotella T in JD gas tractors
John hicks
03-24-2003 18:27:25
Is there any reason I should not use Shell Rotella T oil in my JD H, 50, and 60 gas tractors. Thanks much for the input.
Scott
03-25-2003 18:32:48
 Re: Rotella T in JD gas tractors in reply to John hicks, 03-24-2003 18:27:25
There is an oil out there that is better than Rotella T. Rotella is designed for on highway use where engines are run at full power about 40% of the time in a relitively clean environment. How ever there is an oil designed for off-road engines that operate at full power about 90% of the time in an extremely dirty environment. That oil is John Deere Torque Guard 15w40, that also meets or exceeds all manufacturers specs for warranty.
Robert in W. Mi
03-26-2003 12:45:45
 Re: Re: Rotella T in JD gas tractors in reply to Scott, 03-25-2003 18:32:48
Shell makes an off road version of the Rotella too. I can't think of what the name of it at the moment though. Rotella T has been working in all of my equipment and diesel trucks for a long time now, and i don't have to pay deere prices for it!! Keep your oil changed, and any of the common brand oils are good enough. Robert
F-I-T
03-27-2003 10:34:39
 Re: Re: Re: Rotella T in JD gas tractors in reply to Robert in W. Mi, 03-26-2003 12:45:45
Robert:
Would that be Shell "Rimula" Premium ? I saw that for the first time at my oil dealer. The spec sheet seems to read as if it is more intended as an ag oil.
Frank
F-I-T
03-24-2003 18:43:32
John:
I use it in all my engines, gas and diesel.
The Shell Rotella T 15W-40 product spec sheet says it "meets or exceeds the manufacturer's warranty requirements of virtually all diesel and gasoline engine manufacturers - for both newer and older engines. It is recommended for all on-highway and off-highway applications, especially where all-season use is desired".
I e-mailed you a copy.
Frank-in-Tallahassee
70D // 855
John Hicks
03-26-2003 18:14:10
 Re: Re: Rotella T in JD gas tractors in reply to F-I-T, 03-24-2003 18:43:32
Thanks Much for the info
POPPER DICK
03-24-2003 20:57:48
Frank,
Could you email me a copy of this spec also?
Thanks
Dick in Pea Ridge, Akansas
F-I-T
03-25-2003 05:05:39
 Re: Re: Re: Rotella T in JD gas tractors in reply to POPPER DICK, 03-24-2003 20:57:48
Pop:
It's on the way.
Frank
POPPER DICK
03-25-2003 06:08:49
 Re: Re: Re: Re: Rotella T in JD gas tractors in reply to F-I-T, 03-25-2003 05:05:39
Thank you Frank
Received it this AM. I have been a Rotella T fan for a long time. Use it in all my road vehicles.
Have a great day.
Dick
Ken
03-25-2003 20:01:13
 Re: Re: Re: Re: Re: Rotella T in JD gas tractors in reply to POPPER DICK, 03-25-2003 06:08:49
Which oil company makes the JD oil?
