Front weights question
aaron
03-24-2003 09:35:29
Is there any certain way to tell if the front weight sets for the 520 - 730 tractors are original john deere? I am in the process of getting a 4 piece set and was wondering how to tell if they are correct? The guy said they have the correct jd numbers but doesnt say jd anywhere? I am guessing they are original. Anyone who knows more about them and could help it would be appreciated. Thanks aaron
AlbertoV05
03-24-2003 12:15:03
 Re: front weights question in reply to aaron, 03-24-2003 09:35:29
Aaron,
If you have the part numbers I'll look them up in Deere's AC-1000 catalog.
Al in Iowa
aaron
03-24-2003 19:38:36
 Re: Re: front weights question in reply to AlbertoV05, 03-24-2003 12:15:03
The cast numbers are as follows
RH side wt A5348R 8 could be a 6. 20D is cast below part# LH side wt A5347R 20 D cast below pn 1st front wt A5348R the 8 could be a 5 10 D cast below pn 2nd front wt A5345R 40D cast below pn
AlbertoV05
03-25-2003 14:00:09
 Re: Re: Re: front weights question in reply to aaron , 03-24-2003 19:38:36
Aaron,
Sorry it took me so long to get back to you, but here goes:
The right hand weight is #A5346R (100 lbs.)
The left hand weight is #A5347R (100 lbs.)
The (first) front frame weight is #A5345R (125 lbs.)
"Supplemental" front weights that bolt on top of #A5345R are #A5348R (125 lbs./ea.)
There is no mention in the AC-1000 Catalog of whether they are cast with any marks identifying them as JD.
Hope this helps!
Al in Iowa
aaron
03-24-2003 12:23:16
Alright I will get them from you asap THanks
