John Deere 70
- - - - - NO SPARK!
Matt
03-23-2003 19:32:44
When I bought this tractor it had an alternator on it and was a negative ground. I have since restored it back to the original positive ground system. The distributor has a electronic ignition, but I did not change the distributor. I've heard that the electronic ignitions are different for positive and negative ground. Could this be the problem.
John T
03-24-2003 07:32:39
 Re: John Deere 70 - - - - - - NO SPARK! in reply to Matt, 03-23-2003 19:32:44
Matt, most definitely. The electronic ignitions Ive seen are polarity sensitive, and will only work if the system is wired as they were designed for. If the system you have was not harmed by being wired in reverse polarity???? and due to its cost, if you want to continue using it, I would just leave what you have (generator and regulator) but convert it all back to negative ground by doing as clooney suggested i.e. reverse ammeter leads (if needed) and reverse battery and re polarize the generator and see if the ignition system still works. Any sort of coil or ballast etc wiring should be as called for in the electronic ignitions manual, but post back any more questions.
Good Luck n God Bless the USA and for those of you so inclined, please pray for our troops.
Ol John T Nordhoff in Indiana
Matt
03-24-2003 17:11:23
 Re: Re: John Deere 70 - - - - - - NO SPARK! in reply to John T, 03-24-2003 07:32:39
Thanks alot guys. I really needed the help
Clooney
03-24-2003 02:37:34
Matt, sure could, the electronic ignition has diodes in it & they are directional. There is a different E.I. for positive ground & negative ground.
~You could easily swap your tractor back to negative ground but keep your stock generator & it would look production. All you need to do is reverse the wires at the ammeter, swap the battery cables, & polarize the generator for negative ground, in some cases you might need a negative ground voltage regulator but most of the replacement regulators will work at either polarity. If you have a stock 12 volt internal resistor ignition coil it should always be wired with the positive terminal to the distributor. If you have a replacement coil it should be wired per the directions that came with the coil or with the E.I. system..... ..
Lee
03-24-2003 02:33:11
Most definitely the problem. Transistors do not like being hooked up backwards and will burn up fast if you do. Looks like you did, but it may still work if you hook it up negative ground again. No promises though. Might look for positive ground version of that electronic ignition, or go back to points.
