Removal of crankshaft? What has to come off?
John from MN
03-23-2003 16:55:15
I have removed from my 35 B so far the governor case, block, inspection plate, pisons, rods, and oil lines to both ends of the crank. Do I need to pull the center casting in the middle of the clutch? Does the cover between the clutch and and crank case have to be removed? I&T manual is shady on the exact procedure. Thanks for the help. John
Clooney
03-24-2003 03:29:55
 Re: Removal of crankshaft? What has to come off? in reply to John from MN, 03-23-2003 16:55:15
John, yes the entire clutch & pulley have to come off, as well as the 1st reduction cover & both main bearing housings. Don't forget the oil lines inside. I can't remember on the 35 but probably the cam gear will have to be moved out of the way also.
