Bent Gear Key On D Belt Pulley
cheg
03-23-2003 14:17:03
I pulled the belt pulley on my 1935 D. I noticed the gear key had came partially out of the gear. The key hit a bolt on the crankshaft main bearing and was bent back. I did not see any other damage.
How can I keep this from happening again if I install another gear key?
Thanks
Clooney
03-23-2003 14:34:45
 Re: Bent Gear Key On D Belt Pulley in reply to cheg, 03-23-2003 14:17:03
Cheg, just make sure the key is slightly below the surface of the end of the pulley hub, then use a center punch & stake the hub slot over the end of the key...
