sticky valve on A
JDMAN
01-06-2004 19:30:42
I have a 1950 Jd A, one of the valves is sticky, you can push it in, but it wont come back out, what is the best fix for this???
Thanks.
Paul from MI
01-07-2004 18:42:18
 Re: sticky valve on A in reply to JDMAN, 01-06-2004 19:30:42
I have had really good success with a product called B-12 Chemtool, get it at your local auto parts. I the valve is sticking because of sludge or varnish this stuff will dissolve it quickly. I used it on an Allis B that was so sludged up you couldn't even see the coils on the valve springs. I remove the valve cover and run the engine at an idle, squirting the B-12 on the valves one at a time. Keep flushing until you can actually flood that cylinder & valve enough to cause it to miss, then go to the next valve. After the valves are freed up good, put the rest of the can in the oil and let it run at an idle for 20 minutes or so,then change oil. It will also flush the crankcase.
Good luck,
Paul
John T
01-07-2004 06:23:21
Mornin JD Man, Time, exercise it, and the use of chemicals like Pappy said should get you going. Ive also had good luck with PB Blaster sprayed in the stem area, I would start with it and then open close open close open close etc etc to get the grit and carbon worked out some, then use more lubricant type sprays such as WD 40 etc and do the same, and then drain and flush the oil and add a good cleaner like Rislone to the oil and run it a while and get the old girl up to temperature. Then, the next time you change oil I would use a good top lube like Marvel Magic Oil etc and you should be good to go.
Good Luck n God Bless
John T
Clooney
01-07-2004 03:22:25
JDMAN, start by squirting some carburetor cleaner between the valve stem & valve guide then working the valve in & out by hand [that will remove any gum & varnish].. Then do as Pappy said & work some penetrating oil into the stem to guide area by working the valve in & out by hand..
~You might also look for a weak valve spring [if that spring is weak it won�t put enough pressure on the valve to properly seat it..
~Once running, make sure the valve oiler is dripping oil on that side [it should drip on the exhaust valve only]�. It the oil pipe or drip hole is plugged clean those out..
[email protected]
Pappy
01-06-2004 22:56:31
I would spray the valve stem with PB Blaster, Liquid Wrench, or K-B Knock 'er Loose. Spray and then move valve. Spray again and again until the valve closes by the spring. Then oil it with engine oil real well and work it some more. This should do it.
jdman
01-09-2004 08:02:24
 Re: Re: sticky valve on A in reply to Pappy, 01-06-2004 22:56:31
I moved it some and pushed it in but it wont come back out?!!!! CAN you turn it over with the valve in by hand?
