Impulse spring question
marvin
03-22-2003 18:43:02
can anyone tell me the correct procedure to install an impulse spring on a wico ap477 mag?
Clooney
03-22-2003 19:03:51
 Re: impulse spring question in reply to marvin, 03-22-2003 18:43:02
Marvin, the driven flange goes on first with the pawls facing inward, then lightly oil the spring & with the spring set to coil counter-clockwise hook the outer end into the slot in the drive cup, then wind the spring until it enters the cup, then put the cup on the rotor shaft & engage the spring inner end in the driven flange, then pull the cup back out just far enough to wind the cup & spring 1/2 turn counter-clockwise, then push the cup on, then put a little grease on the bearing surface of the nut & install it, then insert the cotter pin.....
marvin
03-22-2003 20:13:20
 Re: Re: impulse spring question in reply to Clooney , 03-22-2003 19:03:51
clooney, thanks for the pointers, i will attempt to instal spring, will let you know if any problems
