420C carb
RLS ia
03-22-2003 17:30:55
I have a 420 that has a TSXU 837 carb on it. I went to the JD dealer to get a gasket set for it and the ones they got for me didn't fit, the gasket that goes above the bowl was too small. Where can I get gaskets for this and why is there a bigger carb on it? Is it because it is an industial? And what settings should I use to start with before fine tuning the adjustments once running.I've worked on several tractors but Iv'e not been around one of these. Thanks
Clooney
03-23-2003 05:00:13
 Re: 420C carb in reply to RLS ia, 03-22-2003 17:30:55
RLS, I'm not 100% sure but believe that 837 carb is a replacement carb from an old Massey. I sent you a carb data sheet [E-mail] showing the cross reference for that carb & possibly a place that has repair kits...
