JD 70 service man
Ira Biggs Jr
03-21-2003 14:58:03
I have just bought a 1953 JD 70 gas. And i need to get a service man for it. But John Deere dose not make it. And the I&T man will not help me. Put it this way I took it home in the bed of my truck and on a hay wagon. So any help would be a big help.
Thanks IRA
John Van Valkenburgh
03-21-2003 19:45:15
 Re: JD 70 service man in reply to Ira Biggs Jr, 03-21-2003 14:58:03
Looking at John Deere Parts Online they list the technical manual SM-2008 as being available for $35. You probably will have to order it. The dealer should be able to get it for you, but if nothing else you can register with John Deere Parts Online and order it yourself.
The website address is:
Link
Having spent a lot of time fixing up my 1953 model 50 I'd highly recommend that you get not only the John Deere Service manual but also the official John Deere Parts manual for your tractor. You can take the part numbers from the parts manual and see if they are avaiable from John Deere and also get the cost. Lots of stuff still available from John Deere for your machine.
Don't worry that you got the old 70 home by hauling it on the back of a hay wagon. They are not all that hard to figure out and there is LOTS of help available here on the John Deere board.
The 70 is a big machine. Be carefull working on it and most of all have a good time. The first time she cranks up you will have a smile on your face that won't disappear for days. Your wife will think you are up to something.
Best of luck,
John
F-I-T
03-21-2003 16:17:00
Ira:
My manuals catalog shows you '70' gas would use SM-2008. I see that it is called out for the '60-70-620-630', Gasoline and All-Fuel. Maybe that one is a compendium of all those models. Perhaps someone else out there could answer that.
We once had an original '60' service manual that we used as a go-by for our '48 'A', and it was pretty good.
The parts manual will be a real assett.
Frank-in-Tallahassee
70D // 855
ET
03-21-2003 18:29:51
 Re: Re: JD 70 service man in reply to F-I-T, 03-21-2003 16:17:00
I have SM-2008 its the book for a 60. I bought it for my late model A. Information in it would be simalar to a 70. A 70 diesil book would give good info. on transmission stuff but wouldn't help on the engine. Engine torque specs. would be easiest to get from an I&T manuel.
