Compression on 1940 JD A
JR
03-21-2003 06:38:12
What should the compression be when turning the engine through by hand? How many times should it be turned over? Should I see the compression rise after a few turns like you would when turning an engine over with a starter? I have not tested it yet, hope to this weekend.
Thanks for any info.
Clooney
03-21-2003 15:47:11
 Re: Compression on 1940 JD A in reply to JR, 03-21-2003 06:38:12
JR, it depends on how fast you turn it, whether it's hot or cold, what pistons are in it & any other combustion altering modification that have been done over the years.
~Why are you wanting to test the compression? If it's for a starting problem it can be lower than a general engine condition test.
~If for a starting problem you want to test it cold & at only one puff on each cylinder. [probably 50+ psi]. If for total compression & engine running problems test it hot at wide open throttle with choke wide open [probably 65-70+ after about 3-4 puffs].
~You want to see how even it is & you probably want it to be within 5-8 psi from side to side. ~Watch the gage & see how much it gives you the first time over & how much it gains each time over, that will tell a lot about ring health. ~Give it a once over cold test [carb & choke open], then start it & warm it up then give it a hot test, 3 times over [choke & carb wide open]...
~Any questions on your results post back..... .....
