How do check pony coils to see if they are OK
Mark
03-20-2003 09:50:03
Wondering if there is a way to see if pony coils are good without running the pony engine? Is there some test you can do? Also how about checking condensors?
Thanks,
Clooney
03-20-2003 10:39:21
 Re: How do check pony coils to see if they are OK in reply to Mark, 03-20-2003 09:50:03
Mark, there is no fool proof way, but the best way I have found is to use your nose, if they smell burnt they probably are.
~As far as resistance values go, I don�t have exact figures & even if I did there are some different coils & aftermarket coils so they might not be valid. I can give you some general values & if they are way out of whack with those you can assume there is a coil problem. On the coil�s primary [measured between the coil�s power wire & the one going to the points set [everything disconnected], you should be somewhere between .5 ohms & 3 ohms [give or take a little]. On the secondary [measured between the 2 plug wire towers] you should probably be between 5K ohms & 20K ohms [if you aren�t at least in the K range suspect burnt up coils].
~On the condensers about all you can do is measure between the lead & case to see if they are shorted [that should show open on a good condenser ] & depending on your voltmeter you can try to charge them with your volt meter then reverse the leads & see if you can read a charge. ~If you are fighting a �no spark� condition make sure you have power to the pony distributor power in post & that power is getting to the coils. Then if there is any rust on the coil�s core remove the core & clean the rust off. If at any time you left the pony ignition switch on for more than couple of minutes without the pony running, suspect burnt up coils [you should be able to smell them]���..
