G input shaft
KEN C
03-19-2003 20:38:26
The input shaft that the first reduction gear goes on, short shaft, has spun on the bearing and wore a groove in the shaft. If i have it built up and turned back to specs, will the heat weakin the shaft and cause to break, or is this ok to do. Anyone done this, any info is appreciated, thanks Ken. This is on a 52 G.
Clooney
03-20-2003 07:28:01
 Re: G input shaft in reply to KEN C, 03-19-2003 20:38:26
Ken, yes it could. It depends on how deep the weld penetration is & how hot the shaft gets. Done correctly it can be repaired with little damage & future failure. I prefer spray weld then re-machine but that can get rather expensive..... ..
havvey
03-20-2003 05:38:45
i believe it can be repaired by reputable sorces however it might be faster and cost effective to buy a replace ment shart new used or old stock sometimes these parts are available used as they dont sell everyday
KEN C
03-20-2003 17:53:04
 Re: Re: G input shaft in reply to havvey, 03-20-2003 05:38:45
Thanks for the replys, i think i will try and see what happens. The bearing had went out, no rollers left in it, the groove wore on one side, deep on one side and smooth on the other, don't know how that could have happened. Thanks again, Ken.
