JD R radiator
Bill R
01-06-2004 17:59:37
putting new core in model R and was wonderig if I should also replace the neck in the top tank while its apart, (already have to have a new pony motor outlet pipe made for top tank) was wondering how hard this neck is to change
Bill R
A // B // GW // R Diesel
Clooney
01-06-2004 18:33:37
 Re: JD R radiator in reply to Bill R, 01-06-2004 17:59:37
Bill, I have done a lot of things on a lot of tractors but you know I haven't ever put a filler neck flange on an R..
~I would imagine it is like the other old 2-cylinder Deere's & the old one just peels off with a sharp screw driver Then new one drives back on with a block of wood on top & hammer.. BUT, don't bet your paycheck on this until you hear from someone that has done an R..
~One more thing,, don't pull the old one off until you make sure you can get a new one.. Try Deere, if not there try Greg Stephens, or K & K, or Farm power Restoration [610-845-3668]..
[email protected]
Bill R
01-07-2004 11:02:45
 Re: Re: JD R radiator in reply to Clooney , 01-06-2004 18:33:37
thanks clooney, it is the same as the one on later D's if I remember correctly, I saw a couple of those necks for sale at the expo so I should be able to get one. Your help is always appreciated
Bill R
