53 G question?
Jack
03-19-2003 14:51:51
I have pulled my G for a while now w/o problems but it has on occasion jumped out of 1st gear under a load.Why doesen't it come out in second,it's in the same slot,just the high low lever has been moved?I have seen lots of tractors with blocks wedged in there.Later,Jack(TN).
Clooney
03-19-2003 15:19:09
 Re: 53 G question? in reply to Jack, 03-19-2003 14:51:51
Jack, it could be there is more torque on the 1st/2nd pinion while in 1st gear. Or the fact that driving through the idler gear is causing shaft movement. It could also be a sign you have worn & loose trans shaft bearings or worn case bearing bores. I presume it is actually jumping out of 1st & not over/underdrive?
