Cheap fix for steering shaft spline on my 70 w/ps
GORDON
01-06-2004 16:58:33
Needed to replace seal on actuating valve sleeve, found previous owner had welded it because spline was worn. Cut off weld and called dealer, said the sleeve was available for $410, after I got my breath back said I'D let him know. Started looking at car input shaft, found that 86 to 92 chevy s-10 pu had a 1" 11 spline shaft. Went to trans. repair shop bought 1 for 5 bucks. Went to several other auto repair shops found 2 worn clutches free, cut splined center from both clutches, ground to sleeve OD, cut spline off sleeve, welded to sleeve, cut spline off shaft, welded to steering shaft, assembeled and works great. Guess it would work on manual steering too, don't know.
