Hydraulic lines
Aaron
03-18-2003 15:10:22
I have a 620 standard and was wondering how to get out a stuck line from the powertrol housing? I tried using a series of hose clamps then backing the bolts out with a plate pushing on the clamps. This worked with one of the lines. The other is still stuck fast. any suggestions, could I heat up the casting around it? Thanks
Clooney
03-18-2003 15:51:41
 Re: hydraulic lines in reply to Aaron, 03-18-2003 15:10:22
Aaron, the hose clamps are about the best approach & if used with a little heat [I lightly heat the line & fitting then let cool] will usually get that line out. You can tap on the line with a block of wood but don't beat on it too hard as those lines dent real easily.
