44 B Fuel Tank
Scott
03-17-2003 19:23:05
I'm restoring a 1944 B all fuel and I'm getting pretty impactiant to hear the old girl run. I have the small gas tank cleaned enough to keep clean fuel. How long will this tractor run with just the small tank available for gas? The large fuel tank is in pretty tough shape and is going to need a lot of work yet, and i'm real close to being able to get it running. TIA
rick
03-19-2003 04:20:19
 Re: 44 B Fuel Tank in reply to Scott, 03-17-2003 19:23:05
if your big tank is rusty inside or slight pin holes Red Kote is the ticket we sell it for 25 dollars and it is easy call 724 894 2982 it is for the inside and seals out rust
Mike Schotte
03-17-2003 21:01:32
Hi Scott,
Maybe you can help me out. I've got two tanks that I'm assuming are off of a John Deere Model B all-fuel.
Please check these two pictures out and tell me if they are off of the same tractor:
MAIN TANK
third party image
STARTING TANK
third party image
Thank you in advance for your time, -Schotte
Scott
03-18-2003 18:42:27
 Re: Re: 44 B Fuel Tank in reply to Mike Schotte, 03-17-2003 21:01:32
They sure do look an awful lot like my tanks, especially the small one. Pictures can be deceiving, but it looks pretty close to me. Good luck.
Will P
03-17-2003 19:31:14
My 43B all-fuel will run for over an hour on two gallons of gas. That is plowing the field with a 2 bottom plow. I think that little tank is 2 1/2 gallons. Just putting around it will go for a pretty long time.
Will P
