API Lube Oil Spec for a Diesel
Frank, Tx
03-17-2003 17:43:41
What do oils that meet API Spec SF, CD have that API Spec SG,SH,SJ,SL lube oils do not. Would SG, SH, SJ, SH Spec oils be acceptable to use in a diesel engine?
Clooney
03-17-2003 18:38:35
 Re: API Lube Oil Spec for a Diesel in reply to Frank, Tx, 03-17-2003 17:43:41
Frank, the [C] in CD, CE, CF, CG, CH-4 etc. means it's for compression ignition engines & is much better at handling sulfur in the fuel & has more phosphorus compounds & other severe wear additives for high compression diesel use.
~The [S] in SG, SH, SJ, SH & other S type oils means it's for spark ignition engines & in most cases is designed for emission control protection, protection against combustion chamber deposit build up, & enhanced for higher fuel economy & cold weather flowability. Most of the S series oils are not good at handling sulfur in the fuel & some of the high anti-wear additives are removed, modified, or cut back so catalytic converter damage is cut to a minimum.
~You really should stick to a [C] rated oil for diesel use....
