John Deere A
Wilson
03-17-2003 11:23:10
Did John Deere ever produce a Model A with propane? Serial number is around 58000.
What is the best way to repair a hand cluch that will not engage, does not have the pop sound when the lever is moved.
Wilson
Bill
03-18-2003 21:48:46
 Re: John Deere A in reply to Wilson, 03-17-2003 11:23:10
Granpa had a propane A conversion, we still have it, runs good 1950 model;;;; Bill
Dave K (Fl)
03-17-2003 16:16:50
Do you have the operators manual? That tells you how to adjust the clutch. Basically, pry off the cover on the outside of the clutch/pulley. Tighten the castellated nuts about 1/2 turn each, they should all be evenly tight. Then see if the clutch handle will "snap" into position. If it does not, tighten them some more. If they are pretty much drawn up as far as they can be it is time for new clutch facings/discs, avail from JD. If you get them too tight you will not be able to snap the clutch in either.
Dave
CLW
03-17-2003 15:14:19
No factory propane A's. First factory LPG was first numbered series. Many A's were converted by owners.
CLW
Clooney
03-17-2003 13:00:23
Wilson, the best way to repair it is to give it a proper adjustment & if that doesn't make it better then disassemble it & see what's wrong with it. you probably have wear on some [or all] or the internal parts. Probably the sleeve drive pin & sleeve pin hole are worn, the sleeve holes for the toggles are probably worn deeper & at an angle, the pivots & pivot pins are probably worn & sloppy, the adjusting bolts are probably also worn. ~You can put a lot of money into that clutch & still not be sure you have the problem solved. The place to start is look for obvious wear the repair that & see if it gets better, then move on to the less worn parts & see if you can get it working better. ~As a last resort you can machine about .020" from the outboard side of the operating sleeve to get the toggles to go over center farther & get a better snap in.
~If you can find the time you probably should take the clutch pulley off the tractor & inspect it then post back with questions on what you discover.....
