520 pistons
Rich
01-06-2004 15:26:49
Just pulled the pistons out of my 520 (because of a lot of blowby)and found # 2 piston in bad shape with a piece missing.This is a gas 520 and the cylinder bore looks like it will clean up at 0.045. Who has pistons and rings 0.045 oversize and what should I expect to pay. Thanks Rich
ChuckW
01-07-2004 06:10:24
 Re: 520 pistons in reply to Rich, 01-06-2004 15:26:49
believe I may have a set of pistons but not sure if standard or .45 over....if you're interested...I can check out. In relation to a previous post, I had trouble one time with what was called hi-altitude...they gave me LP pistons and the compression was way too high...tractor did not run properly...those pistons were flat on top with no dish...I would not recommend them....I believe I also bought some from Dengler...I always prefer the original John Deere pistons for best operation....
ET
01-07-2004 05:08:01
I bought a set of .045 oversize high altitude pistons from JD about 3 years ago for about $325. It runs real strong with the high altitude pistons.
JerryB
01-06-2004 16:36:50
Rich, give Triple G Service a call ,They have a huge amount of new and used 2 cylinder parts.Toll free # 1888-720-0830.Jerry.
