ABG-90 snowplow
Roger
03-16-2003 11:17:29
Does anyone know if Deere still makes this snowplow or if there is an aftermarket maker or better still plans so I can build my own?
Thanks in advance
gwh
03-16-2003 20:14:06
 Re: ABG-90 snowplow in reply to Roger, 03-16-2003 11:17:29
Roger, the ABG-90(& later called the #90)was made here in Syracuse NY and when production ceased locally a local JD dealer bought a lot of left over parts and unfinished plow assemblys, his son would come home from school and head to the shop and weld up plows for the store to sell. If you can get close to one for a few measurements you should be able make a similar usuable plow. If you can find a light weight plow blade like a MEYERS the rest is basically flat stock, angle and channel iron, add some 3/8"cable and 2 pulleys and pick up a couple of John Deere rockshaft cultivator arms or brackets(you can make homemade extensions for these-as i had to for one of mine) It could be done. gwh
