What are these holes in my cylinder walls?
AlbertoV05
03-15-2003 15:47:06
When I was replacing the head gasket this week on my Model 60 I noticed that there is one hole at the "six o'clock position" in the wall of both cylinders. They are approximately 1/8" diameter and appear to be "man made".
Any idea what these holes are?
Al in Iowa
G-MAN
03-15-2003 16:39:23
 Re: What are these holes in my cylinder walls? in reply to AlbertoV05, 03-15-2003 15:47:06
My JD 60 service manual says they're there for the installation of compression release petcocks (if desired), as Clooney said. They sure wouldn't be as handy as the ones on the side of the blocks on the letter series tractors, though.
Clooney
03-15-2003 16:15:40
Al, look under the cylinder block to see if there are 2 pipe plugs that line up with those holes. If so those are cylinder drain holes. Some people even install compression relief cocks in those holes...
AlbertoV05 - THANKS G-man and Clooney!
03-15-2003 17:24:20
 Re: Re: What are these holes in my cylinder walls? in reply to Clooney , 03-15-2003 16:15:40
