I give up!!!
Wes
03-15-2003 12:53:16
At least for now. I just finished working on my powr-trol unit for the second time and it still won't stay up. I put on a new cylinder cup all new gaskets and new O-rings around the plugs. Now I guess it is time to get the plow ready for spring. Maybe someday the powr-trol will stay up on it's own, but I am not counting on it.
F-I-T
03-15-2003 17:47:08
 Re: I give up!!! in reply to Wes, 03-15-2003 12:53:16
Wes:
Is this your '47 "A" you are having the carb trouble on ?
Have you tried the Clooney test where you raise the Pow-R-Trol with an implement or load on it, then close the adjusting screw on the side of the Pow-R-trol box to see if it stays up ? If it does, the trouble is in the box, if not it's in the cylinder/gasket area.
When it goes down is it putting Pow-R-Trol oil into the rear end ? If so, any chance you have a crack in that cylinder body ?
did you see where the gasket had been blown, or the cup worn/blown out ?
Have you tried it with a remote cylinder ? Is the problem only with the rockshaft.
And finally, did it ever work, and if so, when did it stop working ?
Frank-in-Tallahassee
70D // 855
Wes
03-16-2003 13:54:44
 Re: Re: I give up!!! in reply to F-I-T, 03-15-2003 17:47:08
It is the same tractor. The rock shaft has never stayed up since I bought the tractor. I have tried the Clooney test and it still goes down. I do use remote cylinders and they stay up. The cylinder body is new so I don't think that is the problem. Thank you for all your help on this problem and the other one I posted.
