Edisson Splitdorf magneto
Frank
03-15-2003 07:58:19
Have a Edisson mag on 1938 JD D . Took the larger cover off to clean etc. I think i might not have got the gears back where they were in mesh. Is there timing marks to line up to be sure . Frank
Clooney
03-15-2003 08:11:15
 Re: Edisson Splitdorf magneto in reply to Frank , 03-15-2003 07:58:19
Frank, yes there are gears to line up. It would help to know for sure what the mag is. Does it say CD 010 on the tag on the side of it?
03-15-2003 10:40:17
 Re: Re: Edisson Splitdorf magneto in reply to Clooney , 03-15-2003 08:11:15
Clooney Yes Thats what it says on the mag. Are there timing marks on the gears.
Clooney
03-15-2003 10:55:37
 Re: Re: Re: Edisson Splitdorf magneto in reply to Frank [email protected], 03-15-2003 10:40:17
Frank, yes there are timing marks on the gears. ~Turn the main distributor shaft until the little tic mark on the drive gear is at the top, then turn the points cam until the letter L on the big gear appears in the little window [bottom of the breaker plate area], then start the front cover on the dowel pins & look into that little window & make sure the little tic mark lines up with the L, if so push the front cover on & you are good to go...
