John Deere power-trol
KJ
03-12-2003 19:19:21
This is probably an obvious answer, but can someone tell me what power-trol is? Thanks Alot.
Dave K
03-13-2003 16:25:36
 Re: John Deere power-trol in reply to KJ, 03-12-2003 19:19:21
Dan's answer pretty much sums it up. I have a 1948 Model A with power-trol and it is a decent system but quite low pressure, in the hundreds of pounds. I only use mine to pick up the front of logs a little when I skid them so the chain does not wear and the log does not dig in.
They were sort of primitive to what was offered on other makes of tractors at that time however. It is not a "live" hydraulic system. In other words you have to have the clutch engaged to operate it and ditto the PTO, which also only runs with the clutch engaged.
Dave
Dan
03-12-2003 19:56:51
Powertrol was, is, the hydraulic control on the older 2 cylinder JD tractors. It had a lever on the side to raise or lower the rockshaft. It also had outlets on the back for a remote hydraulic cylinder. There are special plugs used in the remote outlets to use the rockshaft instead of cylinder. You can't use both at the same time. The power trol allowed the user to lift an implement on the rockshaft and stop at any height desired. The forerunner to the powertrol was the power lift. It also operated the rockshaft but the implement was all the way up or all the way down. It used pedals located just ahead of the rockshaft housing under the seat. By pushing down on the pedals you activated the lift to raise or lower. I believe the power trol was really a very good hydraulic control in it's day. I am not sure when it was introduced or when it was last used.
KJ
03-13-2003 17:50:29
 Re: Re: John Deere power-trol in reply to Dan, 03-12-2003 19:56:51
Thanks alot guys. Your info helped me out. I thought it had something to do with the hydraulics but wasn't sure what. Again, thanks alot.
KJ
KJ
03-13-2003 17:44:14
Thanks alot guys. I appreciate your follow-ups.
Your info helped me alot. I thought it was something to do with the hydraulics, but wasn't for sure what. Thanks again.
KJ
