3 cyl 830
Mitchissippi
01-06-2004 10:57:17
My late uncle's 830 has the pto lever behind your left foot. He always said he had to kill the engine to engage the pto. Is this the way it's setup, or is something out of adjustment?
The only similar tractors I ever ran were a 2240 and a 2630. These two had the pto level ahead of the shift levers, under the steering wheel.
buickanddeere
01-06-2004 11:27:50
 Re: 3 cyl 830 in reply to Mitchissippi, 01-06-2004 10:57:17
He had not read the manual and had the two stage clutch properly adjusted or repaired. Pushing the clutch pedal all the way down disengages the pto clutch after the driving clutch disengages. Great outfit for baling hay hay if an amature is driving. Just hit the clutch and brakes to stop everything in a real jam.
Mitchissippi
01-06-2004 12:04:34
 Re: Re: 3 cyl 830 in reply to buickanddeere, 01-06-2004 11:27:50
He bought the tractor used and I bought him a manual for it about two years ago.
He ran it like this for years so I didn't argue with him.
I did help him replace the pilot bearing not too long after he bought it. Do you think we may have got it all out of adjustment when we split the tractor?
Sounds like I could adjust the linkage to fix this problem.
Thanks,
Mitch
david val
01-06-2004 14:39:37
 Re: Re: Re: 3 cyl 830 in reply to Mitchissippi, 01-06-2004 12:04:34
make sure the pedal makes full movement, about 1 inch free play and then all the way to the footrest support.
if the free play is not about 1 inch (at the top of the pedal) adjust it with the adjustible link.
if it does, you should feel the extra force needed to disengage the pto clutch: you depress the pedal down to a 'stop' about halfway down and then you apply some more force to the pedal and it moves the rest of the way.
if you don't feel the two stages, maybe the pto clutch was disabled: there may be a plate at the end of the clutch pedal that connects to the linkage. in order to able the pto clutch, you have to loosen the bolt that holds the plate (3/4 inch wrench), pull the pedal all the way up and tighten the bolt (tight!!)in this position.
if you still don't get the two stages, then the problem is whithin the clutch. there is a procedure to adjust cluch levers through the opening in the housing. post again if needed.
david
Mitchissippi
01-06-2004 15:48:54
 Re: Re: Re: Re: 3 cyl 830 in reply to david val, 01-06-2004 14:39:37
Thanks David. I'll get a chance to look at it this weekend, I hope.
Mitch
buickanddeere
01-06-2004 12:42:03
Linkage hopefully, could be assembly? What is freeplay on the pedal now and how far from the bottom before it quits driving the rear wheels. Our 2020,2120 and 2130 had the same setup.
Mitchissippi
01-06-2004 13:47:34
 Re: Re: Re: Re: 3 cyl 830 in reply to buickanddeere, 01-06-2004 12:42:03
I'll have to look at it closer to say for sure. I'll check it out on my day off. May have more questions.
Thanks buickanddeere,
Mitch
