JOHN DEERE-H
GERRY
03-12-2003 16:46:47
SHOULD I ADD 2 CYCLE OIL OR MARVEL OIL TO AVIATION 100 OCTANE LOW LEAD AND TO WHAT RATIO DO I MIX THE OIL TO THE GAS. IS THERE A MAJOR DOWN SIDE TO AVIATION GAS SINCE IT STARTS SO WELL ON IT AND RUNS WELL. I JUST DON'T TO DAMAGE MY H. I ONLY USE IT FOR SHOWS.
Clooney
03-12-2003 17:55:39
 Re: JOHN DEERE-H in reply to GERRY , 03-12-2003 16:46:47
GERRY, I usually wouldn't recommend 100 octane av gas in an H, but if it starts good, runs good & you don't mind paying extra for something you don't need, it won't hurt anything. That gas is a little dry so a little extra lube sure wouldn't hurt. The 2-cycle oil will work good & there is no exact mixture required, just add a small can to about every 10 gallons of gas or more precise a little to every tank full of gasoline.
GERRY
03-12-2003 19:13:44
 Re: Re: JOHN DEERE-H in reply to Clooney, 03-12-2003 17:55:39
THANKS FOR THE INFO AND IF YOU SAY IT WON'T HURT THAT IS GOOD ENOUGH FOR ME. YOUR THE ONE I TRUST MOST ON JD-H'S
