4010 lp
Steve
03-12-2003 13:32:24
There is power to the coil with the switch on but the tractor will not run. I ran a 12 volt hot wire to the coil and it will run. The coil is 6 volt. Are the points and condenser 6 or 12 volt? Any ideas what is bad? There are resistors on the back of the iginition switch, does it start on 12 volt and run on 6 volt? Thanks, Steve
Bob F
03-12-2003 16:15:10
 Re: 4010 lp in reply to Steve, 03-12-2003 13:32:24
Steve
We just put an electronic ignition kit on our 4020 LP. I was told by a JD mechanic that the tractor is supposed to start on 9 volts and then run on 6. If your tractor is like ours, you will have 2 wires running to the neg. side of the coil. One wire is a 6 volt lead and the other is a 9 volt lead that feeds from the starter. I don't think you should have a ballast resistor on your 4010. I think they quit putting them in when Deere went to the New Generation Line. I'm probably already in over my head on this discussion and I hope I haven't given you any false info. Hopefully somebody will correct me if I'm wrong. It sounds to me like you might have a weak coil. Putting 12 volts to it might be bumping the voltage up enough to keep it running. Does the engine try to fire when the starter is winding and then stops firing when you let off on the starter? If so then you either aren't getting enough voltage to the coil or it is weak enough that 6 volts isn't enough to keep the coil energized. Just my 2 cents worth (from a pretty poor corn crib mechanic).
Good Luck
Bob
