A John Deere in a Vo Ag class
Lee
03-12-2003 07:10:29
Guys,I need your help.I am a vo ag teacher trying to guide a group of students through the rebuilding of an A ser. no. 549039.It has a power block with pistons that measure 5.99''.We need to locate rings,gaskets,and rod bearings.I think the rods are a later style because they have replaceable inserts.We have made it this far by monitoring this site and videos out of Green Magizine.By the way,I have already checked my local Deere dealer.Thanks Lee
Steve from Mo
03-12-2003 08:43:31
 Re: A John Deere in a Vo Ag class in reply to Lee, 03-12-2003 07:10:29
Lee,
The rods should be from a JD 60 if nothing other than the Power Block was changed. (No stroker crank or aftermarket stuff).
Good luck!
Steve
kkreek
03-12-2003 07:59:27
Lee, I too am an ag teacher. We are doing a JD70D. I found many of the parts under the "Tractor Parts" section of this site to the left of this post. I like to buy from them because they help support this site. Never had any problem with them. Email me if I can help. kkreek
Drew
03-12-2003 07:44:47
You can get the piston rings from Total Seal,(800) 874-2753; I forgot how much they were, but I dont think they were that bad. Get the head gasket from an auto parts store and not Deere, its alot cheaper. Its fel-pro part# 7744sbx. You should be able to get the rest of the gaskets from Deere. You are correct that the rods are later because of the insert bearings. Im not sure, but Deere might have the rod bearings too. Hope this helps
