jd 2150 with loader, hydraulic pressure
mark sullivan
03-12-2003 00:17:34
my 2150 has a jd 175 loader on it. seems to work awfully hard to pick up round bales. is there any way to adjust the hydraulic pressure to the loader cylinders? or to turn up the pump pressure? any info appreciated.
Jim B
03-12-2003 06:11:18
 Re: jd 2150 with loader, hydraulic pressure in reply to mark sullivan, 03-12-2003 00:17:34
Mark,there is a screw/with jam nut in the main hyd pump that will adjust the stroke control valve.Turn it in to raise pressure but you need to put a gauge in hyd system.2400 psi would be maximum.I think it came from factory set at 2250psi.Have you changed your filter and checked sump screen?Also internal oil leaks can have an effect on hyd operation.Jim B
