4020 hydraulics
S. Conner
03-11-2003 23:00:35
I've got a 4020 and when I start it up after it's been sitting a few days, and I raise the 3-point with no load, the lift arms have a lot of vibration in them. It lifts a load just fine and it doesn't do it with a load. I've just been curious what causes this or if it's something I need to worry about. I kind of wondered if some of the plungers in the pump might be sticking when the oil is cold and this causing a pulsation. Thanks for the info.
Mutsky
02-26-2004 11:44:23
 Re: 4020 hydraulics in reply to S. Conner, 03-11-2003 23:00:35
Does anyone know the Service Bulletin # or a date the bulletin was published? Thanks
JD68
03-12-2003 08:39:21
my 4020's been doin it for 25 years. It's a weak spring, bad seator ball in the check valve.
No matter cycle he hitch once or twice and your good to go.
Fred G
03-12-2003 05:55:52
My 2520 does the same thing. Usually works fine when warmed up. My guess is a leaking seal. Hydraulic system has never been touched, after 35 years it probably needs a little tlc.
bill
03-12-2003 05:54:29
Ours does it too, I think its one of those deere exclusives,
zane
03-12-2003 05:24:40
I don't know what causes it, but mine's been doing that for years. Doesn't seem to be getting worse or better. Works OK though after it's been through a stroke or two.
Jim B
03-12-2003 06:17:18
 Re: Re: 4020 hydraulics in reply to zane, 03-12-2003 05:24:40
There is a check valve that is letting hyd oil return to sump after tractor sits for a while.Hyd system has to refill itself after startup.Jim B
Louie
03-12-2003 15:54:55
 Re: Re: Re: 4020 hydraulics in reply to Jim B, 03-12-2003 06:17:18
Gentleman Jim B is correct.The oil is draining back into the tranny after shutdown.There is an inexpensive fix to the problem. Your local dealer has the parts to fix. about 10.00.You need to install a check valve in the return line.This is easy to do,I would highly recommend it.this is available for 3020`s and 4020`s at least.Tell the dealer there was a service bulletin on it.
MIKE
03-12-2003 18:44:07
 Re: Re: Re: Re: 4020 hydraulics in reply to Louie, 03-12-2003 15:54:55
I think we used to thread the elbow fitting, on the kline to the pump and install check valve, I think it was out of 2630 hyd pump , been to long to remember. These guys are right there should be a service bullitin.
