DIFFERENT PIVOT PLATE FOR JD-4520?????
JD PULLER
01-06-2004 08:39:29
Will a pivot plate from a 4320 or 4430 bolt up to a 4520? Looking to put a lighter weight front end on this tractor than the heavy stock one. Any information about a light weight replacement would be appreciated.
G-MAN
01-06-2004 09:52:22
 Re: DIFFERENT PIVOT PLATE FOR JD-4520????? in reply to JD PULLER, 01-06-2004 08:39:29
Those tractors don't have a "pivot plate". In those tractors, the front axle attaches to the large, heavy cast-iron steering motor, which is little if any lighter than the front casting currently in your 4520. Even the narrow front versions of those tractors (pretty rare), use the large steering motor. I believe this subject has been covered several times, and the general consensus is that you're going to have to build a lightweight front axle and mounting arrangment, or modifiy an existing axle of some sort, and steer it with a regular cylinder, much like the factory arrangment.
