JD24 Skid Steer
Brian
03-10-2003 17:10:43
Hi Group,
I have found alot of info on this board in the
past and hope someone can help with a problem I have with my jd24 skid steer.
I rebuilt the variable drive because of a small leak.
Now when I operate speed lever the variable drive sheeve will only move a small amount (1/2").
Before the rebuild it worked fine (except for the leak)
I tried priming the cylinder but no luck. With the belt off the sheeve moves the full range with no binding.
I have hydraulic pressure because the bucket works fine. Any Ideas or solutions?
Thanks
Brian
