Axle Bearings
aaron
03-10-2003 14:35:04
What is the best way to remove and replace the bearings on the axle on a 620? Thanks to those who reply
Clooney
03-10-2003 16:52:13
 Re: Axle Bearings in reply to aaron, 03-10-2003 14:35:04
Aaron, I presume you are talking about rear axle bearings? The best way is to have someone else do them,,, but your question more than likely pertains to you doing them?
~You have to drain the trans/rear axle housing, then pull the hydraulic lines loose, then pull the battery cables loose & from the battery box, then pull the PTO operating rod loose, then pull the platform off, Then {I usually remove the battery box}, then pull the VERY TOP HEAVY rear housing off [you can hold it up with a chain fall & just roll the tractor away from it], then jack the rear of the tractor up & block the rear of the tractor up in a safe manner, then pull the rear wheels off, then remove the big nuts from the bull gears & either pry or use the axle nuts & steel plates to force the axle shafts from the bull gears & axle housings. ~Once the axles shafts are out you can pull the outer bearings from the shafts & replace the axle bearing races in the housing & renew the inner axle oil seals. ~It isn't a very completed job but sure is a lot of heavy & dirty work.
aaron
03-10-2003 16:58:37
 Re: Re: Axle Bearings in reply to Clooney, 03-10-2003 16:52:13
Sorry for not clarifying, I got a new used set of axles from dennis polk because someone torched mine off before I bought it. I was just wondering if the ones that are on the axles need to be beaten off and how you recommend doing that.
Clooney
03-10-2003 17:09:12
 Re: Re: Re: Axle Bearings in reply to aaron, 03-10-2003 16:58:37
Aaron, the inner bearings should come off when the axles are removed & the outer bearings should tap off with a drift & hammer [if they haven't been spinning & seized themselves to the axle shaft]... If you are careful those outer bearings can be removed without damage or damaging the outer retainers. Worst case is to use a bearing splitter & an arbor press.
mike francis
03-10-2003 20:40:53
 Re: Re: Re: Re: Axle Bearings in reply to Clooney, 03-10-2003 17:09:12
I think there is 2 different sizes of brgs for 620 630 depends on your thread width, make sure you get the right brg to fit your axles and races to match.
