Fuel leak on 37 A
barry from Co.
03-10-2003 10:04:52
How do I stop the fuel from leaking where the sentiment bowl bracket screw's into the gas tank, I'm afraid to tighten it anymore. thanks in advance
Clooney
03-10-2003 11:35:48
 Re: fuel leak on 37 A in reply to barry from Co., 03-10-2003 10:04:52
Barry, more than likely the soldered on fitting plate is leaking at the solder joint to the tank bottom. Clean it up & look closely but that is where most of those old Deere tanks leak. To repair that correctly the tank should be removed & the thank purged of ALL fuel vapors then the fitting plate re-soldered. If you are lucky it might just be leaking at the threads, but most aren't that easy [or lucky].
~If by chance it is just the fitting threads to the sediment bowl leaking all you have to do is remove the sediment bowl & clean the threads then use a good quality Teflon based pipe sealer on the threads, [don�t use Teflon tape]�
Barry
03-10-2003 12:25:03
 Re: Re: fuel leak on 37 A in reply to Clooney, 03-10-2003 11:35:48
Thanks for the info, i used teflon tape when I when I put the sediment bowl back on, I suspect that is the problem, but will check both. Thanks again.
Clooney
03-10-2003 12:36:18
 Re: Re: Re: fuel leak on 37 A in reply to Barry, 03-10-2003 12:25:03
Barry there's nothing wrong with the Teflon tape as far as thread sealing is concerned... It's the possibility that a piece of that Teflon tape could get cut off by the threads & work it's way into to the carb or shut-off valve & cause problems...
