JD Model R Shutters
mark
03-10-2003 08:07:48
The shutters on my R are fairly well rust-frozen and I'm looking for suggestions to help free them up...any suggestions???
Harry
03-10-2003 19:12:39
 Re: JD Model R Shutters in reply to mark, 03-10-2003 08:07:48
I ended up taking my shutters all apart also and cleaned them up then put them back together and now they work very well. Its alot of work but about the only way to get them working.
walt R
03-10-2003 18:01:43
The shutter on my R was shot and when I bought a used one it too was seized up due to rust and dirt. I soaked it with WD40 for about 2 weeks plus trying to wiggle the vanes every few days. Finally I took it all apart and cleaned all the holes. When I got it all cleaned up and put back together it works very easy. I should have taken it apart and saved 2 weeks and a couple cans of WD.
old fashioned farmer
03-10-2003 16:51:28
Howdy,
Used wd-40, a little motor oil, let 'em set for a few days, came back, did some more wiggling. With a little patience and a little wd-40 I had mine workin just fine. God bless.
--old fashioned farmer
F-I-T
03-10-2003 08:42:18
Mark:
If you can put them in an electrolysis bath, the rust will be gone, and probably loosen up the shutter joints at the same time.
Otherwise, a little bit of your favorite penetrant, a little propane heat, a little gentle wiggling until freedom of movement is restored.
Frank-in-Tallahassee
70D // 855
