435 HYDRAULICS
arnie1968
10-19-2003 17:32:47
Putting my 435 back together, Filled the touch o matic. Do you need to get oil to the pump somehow to prime, or are they self priming? Mine has been totally drained. I see all the the hoses and pipes run up hill to the pump. They go over the fuel tank and down to the pump. I don't see a priming plug on the pump any where. How do you get the lines full??\
Thanks Kevin
buickanddeere
10-20-2003 20:19:24
 Re: 435 HYDRAULICS in reply to arnie1968, 10-19-2003 17:32:47
We filled the pump from the output line side with 1 quart of oil while turning the pump backwards by hand. No problems except to get the single dual rockshaft pins/valves to slide out internally when going from separate to single lever dual operation. Which injectors,pistons,valve springs,rods and muffler are you using?
ARNIE1968
10-21-2003 18:50:42
 Re: Re: 435 HYDRAULICS in reply to buickanddeere, 10-20-2003 20:19:24
Just rebuilt it. Have the n-series injectors #35
And n-series pistons. rods are stock
I have the small round muffler.
Does the muffler make much difference in these? It runs like a champ. Just started it yesterday. Turned over about 6 times before it fired and was running. Starts real easy now. As soon as you hit the switch
